ZIP UGNX ASSEMBLY 1
gcrow
Automotive
May 23, 2013
25
Does anyone know of a program that will zip or export a UG assembly file from one folder to another besides cloning an assembly?
Move the files to a directory with a shorter path name.
That may be a limiotation of the coding.
And why does anyone create so many folders with long names that it takes a whole book to navigate down to the file level is beyond me. Even MS found out that using c:\users\ is easier than c:\Documents and Settings\!
KISS works. So does FFF.
Ben Loosli
Hi Ben,
limiting the path length to avoid coding limitation,
that like when you tell your doctor: " it hurts when I stand on my left foot" ,
and he replies: " well don't stand on that foor then " !
I installed per the readme file and I get this error when starting NX, and when I open the zip assembly program it doesn't list any of the parts.
"The procedure entry point UF_DISP_regenerate_display could not be located in the dynamic link library libugopenint.dll"
Any ideas?
NX 8.5.1.3
Make sure that you're installing the correct version (32-bit versus 64-bit).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
