HeavyCivil
The PE exam is coming up on Friday and I keep stumbling on a certain problem in my practice tests.
The problem is very simple and should be easy points on the actual exam if it appears: "Given an allowable stress and a bending moment select the lightest wide flange". Cake, right? Mn=Mp=FyZx
The black book (aisc 13, which will be used for the test this spring) says plastic modulus Zx is used (both ASD and LRFD). But these practice tests want you to use the elastic section modulus Sx. Am I missing something or are these expensive practice test books incorrect? Frustrating to pay top dollar for the latest addition and have reference outdated steel code.
