1
- #1
SBaugh
- Mar 6, 2001
- 6,685
Hello all,
(This is a little bit of an older tip, but I thought some of you may find this to work as well if not better than my previous post.)
I just sat down with the file that started the post about Compressing files. That particular file has 28 helixes in it. So you can imagine how much of a pain it is to load, and save. The file is a Braided Hose (just the outer metal braided section, not the hose itself) and it saves, after I run the Unfrag Utility, at just around 5.15MB. I tried just Winzipping it, and it only compressed down to 4.06MB.
So I went back to the model and extruded a box around the outer most diameter of the Braided Hose. I then re-saved the model and closed SW. I then ran the Unfrag Utility and went to Windows explorer and checked the file size. The size was down to 73.5KB. I zipped it down to 21.0 KB. More than small enough to even send over hotmail accounts.
I named the feature "Delete Me" so when someone gets the file they will know to delete that feature. That will bring the model back to where it was right before I extruded that last feature.
I hope this will help you be able to send more files this away if you need to.
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
Scott Baugh, CSWP
sjb@kochllc.com
