maxlogan
- Jul 8, 2003
- 6
Has anyone tryed using a bar and plate constructed core to be used as a radiator in a motor vehicle, high output apps. Basicaly I need to have a smaller radiator then the OEM unit, and also have to cope with greater temp loading. I have replaced many 'tube and fin' constructed charge coolers with a smaller frontal area 'bar and plate' unit and achived lower charge outlet temp. If I were to keep the aprox radiator volume the same but change the frontal area using the 'bar and plate' core, does anyone have an idea how this may effect engine coolent temps.
All calculations tell me that i will have a slight advantage, all my engineering colegues say otherwise.
Have ordered core and will test, but its a few months away.
I would appreciate any input.
