Leaking on a pipe
KevinCLe
Chemical
Sep 25, 2001
1
I was trying to estimate the leaked volume from a 6" pipe liquid product. Assuming that the leak is 1/4" diameter and head pressure is 100psi.
Thanks in advance for your helps.
Kevin
You could use a standard orifice calculation if its an estimate. Dont have the formula with me - but most text book and API 520 should provide the information
Best Regards
Morten
