help microcontroller transceiver
danieleborsari
1
hi,
probably my english won't be good..but my problem is:
2 modules with microcontroller+sensor+transceiver...
the only problem I've is...
send an encypted data from a module o the other via radio (wireless) end decrypt it when it'll come..if it'll come!!
have you some suggestions about (I must use C programming language to implement the communtication).
if you have some sites with examples or other..
I'm new in this kind of field.
thanks
Daniele
Funny, this was the topic of my masters thesis many moons ago. I had to do this over a ham radio link (FSK modem with P-CSMA and encryption using an X.25 protocol hosted on a TI DSP platform). What is your encryption method? Is your problem with modulation or encryption?
Vince Socci
