Ok guys,
Welding AISI 1144 resulfurized steel... a.k.a. "Stressproof"
I'm aware of (some of) the implications of the sulfur content. Anyone out there had any good/bad luck welding this stuff?
Spec calls for a 3/8" fillet weld on an A-36 ring to be welded to a resulfurized 1144, 3 1/2" shaft...
My inclination is to go with E 7018 SMAW process with about 400ºF preheat.
Russ Newell
Russ Newell
