Mech151
- Jun 27, 2004
- 48
I have a simple part I am trying to analyze. The problem would be similar to a u shaped part with opossing forces at the legs (final deformed part would look more like an o). I would prefer to use workbench for this analysis, but could switch to Classic Ansys if it is required. The 'legs' are not in initial contact. What contact settings can I set that will allow the gap to close before a reaction occurs at the interface. The actual geometry is a single solid body. When I try compression only contact elements the gap between the legs will not close.
