Guest
Does anyone have much experience (good and/or bad) using carbon dioxide (to form carbonic acid) for pH control in water treatment systems? There is a number of advantages of using CO2 versus mineral acids such sulfuric acid. What are the disadvantages? Significant scale deposits and exchanger fouling from loss of CO2 (causing the bicarbonate to revert to carbonate and subsequent scaling)?
If you converted to CO2, were there any operational problems to particular operation requirements?
