CCR limit vs. Octane
phasers
Automotive
Jan 6, 2002
9
Not much activity here....time for a new thread:
OK, I was looking at some old notes on octane ratings describing four fuel ratings:
Motor Octane Number (MON)
Road Octane Number (RON)
Supercharge Octane Number (SON)
Research Method.
At the pumps I usually see a sticker that shows the (R+M)/M method to calculate the octane of the fuel.
The SON number really applies to aircraft fuels which exceed 100 octane running from one hundred to several hundred. It does not apply to unblown engines.
A non blown engine will start to lose power if the Octane exceeds about 100 MON or 104 RON (I remember 102 gas, anybody ever see 104 at the pump?). A 100 MON gasoline could easily handle a 15:1 compression ratio in most engines.
Because high octane fuel is a mixture of ingredients that want to ignite vs. ingredients that don't want to, we get fuel that is a compromise between what is acceptable for emmissions and for power/economy.
SO...your $64,000 question:
Because we build our engines to the available gasoline specs that are given us, are we at our limit?
Not because we don't know how to build high compression, fuel burning marvels of technology. We've figured out how to control things like chamber temperature with EGR and the like, and we've increased efficiency with port injection, but because the formulation of fuel currently available can't handle anything above a certain parameter and until we either reformulate or change fuel delivery methods (DI ?) is this it?
Phasers
