Roachman
Automotive
- Jun 17, 2003
- 13
I have 2 drive pinions which I need to harden. The material is 42CrMo4. One of them has 29 teeth at 4.5 module and a face width of 40mm meshing with an 88 tooth slewing ring. The other has 27 teeth at 4.5 module and 44mm face width meshing with a 68 tooth slewing ring. Both are 20 degree pressure angle.
Can I achieve a contact fatigue limit of 1140 MPa and bending fatigue limit of 450 to 600 MPa by induction hardening the gear tooth faces and bottom as this would give me the desired gear life with this material.
The slewing rings are to be of the same material and the manufacturer informs me that the tooth faces will be at a hardness of 55-63 HRc. Is this degree of hardness capable of being produced by induction hardening alone?
Ref:- thread406-119499
