13to0
- Mar 3, 2007
- 2
Does anyone have any input as to the structural engineer's standard of care responsibility when it comes to the design of interior and exterior non-load bearing partitions? Typically, our proposals are written to exclude this from our design since they are not part of the superstructure. This is usually not an issue on larger projects where this portion of the work is typically subcontracted out and reviewed in the submittal process. Recently, however, it has become a constant issue of debate with our clients on smaller projects where they want us to design, detail, and issues specifications for the non-load bearing walls. Any experiences or input would be greatly appreciated.
