StoneCold
Chemical
- Mar 11, 2003
- 992
What method do you use at your chemical plants to dispose of your waste water? Waste water being water that contains solvents as well as some solids? Are you evaporating the water and separating the solvent out either as a descrete phase or with carbon and then recycling the water? Are you incinerating it, either on site or off site? Are you filtering it and running it through membranes?
I am looking for some suggestions as to a practical way to dispose of 15,000 gallons a week of water contaminated with solvents,organic molecules and miscelaneous salts.
