Change sketch surface
yayaya25
Materials
Jan 3, 2007
36
I have a sketch I made from an existing sketch an dI want to move that sketch to a surface so I can cut into it with out having to re draw it on the surface I just want to edit the sketch plane, but you can't edit the sketch plane once you have made a sketch form an existing sketch. Help! Thanks!
Yeah the copy and paste thing works but it doesn't really place it where I want it. I usually just show the sketch and if it's parallel with the surface I just resketch over it. It works too but if there was a way to transfer the sketch from the top plane to the surface that would be great. Without copy and paste. Thanks!
Right-click on the sketch in the feature manager, edit sketch plane, select the surface you want the sketch on.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
When you create sketch from selections you can't choose edit sketch plane when you right click.
Did you use convert entities? If yes, you would have to break all the coincidences then move the sketch plane.
Chris
AutoCAD 06
yayaya25,
Try a derived sketch, that should do what you want.
Regg
open the sketch and view all mates and delete all the on edge mates then you should be able to do what you want.
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
