Recently, I went on a site inspection and saw plate washers instead of regular round washers on the base plates.
Is it common to have plate washer(3"x3"x5/8" thick) on top of base plate? Does it make any difference structurally?
The only reason I can think of is to cover up the oversized holes of the base plate.
At one location, the contractor had put 5 plies of plate washer. This location had a X-bracing also.
thanks
thanks
