Changing Font Size of a dimension
cutter112
Aerospace
May 3, 2007
5
I am working in Catia V5 R17 Generative Shape design and need to increase the font size of my dimensions. I can revise them in 2D but have had no luck in a normal 3D model. I look forward to someone showing me the way!
Are you asking about dimensions in a Sketch (constraints), or dimensions you made with the FT&A workbench (annotations)?
and annotation or dimension in GSD 3D. I understand how to revise the font size in sketcher.
OK, I am really going to show my ignorance! What is an FT&A workbench?
Functional Tolerancing & Annotation Workbench.
Y14.41 Compliant workbench that you are using to make your annotations in 3D.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
OK lets continue to expose on my ignorance! Exactly how do I get to this workbench? and then, what do I do to revise the font size and style of my dimension text.
I'm guessing that someone has customized your environment...
How are you adding dimensions with the GSD workbench? There is no "dimensioning" capability in GSD (unless it was added in R17).
Are you able to get to the PROPERTIES of your dimensions, and can you change the size there?
Yes I can get the properties popup in my dimensions. I can revise the color and size of the lines and revise the color of the background in the box around the dimension but there is not font tab as there is when I view a dimension in 2D or sketcher.
Any chance of posting an image of your screen, so we can try to figure out what you're working with?
If not, what highlights in the tree when you select the dimension?
I'm still not sure how you're creating those 3D dimension?
From his description of it sounds like he may just be using the "measure" button.
But I'm not sure how to change the size on that.
--Jay
