AutoTURN (Transoft) Exception error
Hoagie
198
Anyone have trouble launching AutoTurn after loading? I've just loaded it and keep getting the following errors:
C:/Program Files/Transoft/AutoTurn5/AT2000.ARX ARX Unhandled Exception C0000005 (Access Violation Writing Oxccccccd0 at address 77c2a573d
Thanks for reading,
H.
What version of AutoCAD and what version of AutoTURN are you using?
I have had trouble with it loading on occasion, usually if I get a new computer or as recently just upgraded to AutoCAD 2007 (company decision not mine). What I have done is at the COMMAND prompt in AutoCAD type in APPLOAD and click on BROWSE. Go to the directory where the .ARX files are located (usually under PROGRAM FILES\TRANSOFT SOLUTIONS)and click on the .ARX file. Hit LOAD and put it in your STARTUP SUITE. That usually does the trick.
