khardy
- Jul 7, 2004
- 74
I am designing a pipeline to transport #6 fuel oil from an off-shore mooring to a terminal. Distance from the terminal to the shore is 5-miles and the line will be buried for the entire run. The distance from the shore to the mooring is 1.5-miles. The product is #6F.O. with a 400cSt viscosity at 120F. Deliveries will be made every four months or so. The site is in the Caribbean where the temperatures rarely get below 75F. The product will be received heated to 120F. What is the best way to leave the line after the delivery to ensure we can receive product the next time?
1) Leave it in the line. Pros: easiest. Cons: product could solidify to the point the ship can’t pump the slug out on the next delivery.
2) Fill the line with sea water. Pros: cheap. Cons: corrosion, environmental.
3) Fill the line with air. Pros: no corrosion or slug. Cons: compressor expense, don’t know how easy this will be operationally, fire hazard of fuel / vapor mixture.
4) Fill the line with fresh water with corrosion inhibitor and re-use the same water each time. Pros: no corrosion or slug. Cons: expense of water storage tank & pump.
5) Steam trace. Pros: common. Cons: Expense
6) Other ideas?
I’m hoping somebody with operational experience can help with this.
6) Other ideas?
