jec3300
Automotive
- Jan 30, 2006
- 55
We are currently having a discussion on straightness vs. flatness. Here is the scenario: we have flat mounting surfaces that we need to check in respect to “flatness”. We currently use a “U” shaped block that the part surface can slide into. The gap is set to material thickness at MMC and the tolerance for “flatness” added. Is this best called out with straightness or would flatness be better? My thinking is straightness because of the mmc call out on the material thickness. Any ideas?
