automechanicar
- Nov 28, 2007
- 22
Almost everytime I try to hexmesh solids in Femap I get this massege:
"Solid can not be meshed. Either Meshes on lateral surfaces are not fully mapped or base and top surface meshes do not match."
This also happens often when I try to mesh relatively simple goemtries, like cylinders.
The tetmesh works fine. What's causing these problems with the hexmesh? Does any one know?
Thanks in advance!
Thanks in advance!
