vincentpa
- Nov 9, 2005
- 223
I am designing a strip mall with rather high parapets. The mall is a steel framed building with steel bar joists on steel beams. The roof is a built-up roofing system. The typical parapet height is 5 feet and the parapet at the mall entrance is 10 feet. We need to brace the 10-foot parapet for sure. I haven't checked the 5-foot parapet yet. The parapet and facade is EIFS on 6-inch metal studs. We only can work with 6-inch metal studs for facade and parapets. How do you usually brace parapets on the roof? We were thinking to put metal studs at 45 degree angles and put plywood sheathing on top of the studs. The roofing would go over the sheathing to the parapet. I've noticed on some of the big box retailers that the parapet signs are braced with what appears to be steel pipe. I don't know how the connection to the studs and roof joists is made. Is there a name for this type of bracing? I thought I read of a name or a proprietary product. So the main question is, how do I brace the parapet?
