Find and for
thom86
New member
Jul 22, 2008
6
Hi
i have a little problem with a program. As you can see on the picture it doesnt recognize "b".
This calculation works without "for".
If anyone has an idea please tell me.
regards,
getfile.aspx
I don't think you can use a solve block within a program. To do so would require typing in the "Given" as a programming operator. You can't type in programming operator; you have to use the programming toolbar or keyboard equivalents. "Given" is not available on the programming toolbar.
You need to create a function that implements the Given-Find, ala, func(x,y,z):=find(a,b,c), then call the function from within the program
TTFN
FAQ731-376
Thx for your answer.
Do you have any clue on how i can do that IRstuff ?
This is kind of an extreme example. It is trying to minimizie the coefficients of a differential equation so it will reach a setpoint quickly.
ftp://ftp.deltacompsys.com/public/NG/Mathcad%20-%20ITAE2.pdf
thank you very much for your help guys
