A general question on how to set the display of the number in MathCad
hellowworld
Chemical
Sep 16, 2008
1
Hi everyone,
I am a new mathcad user
I have a question on how to set the out put of the "solve" function in the "symbolic keyword toolbar"
I defined an equation in terms of some constant variable (I mean I have assigned a numerical value to a variable) and I use the solve function
Eg.
a:=100
a*x=50 solve,X --> 50/100.00000000000000000000000
my question is how to ask mathcad to give me the overall result instead of giving me a numerical expression
I have been searching in the help file for an hour now..
I guess it is probably mentioned in somewhere that I overlooked.
Please tell me how I can ask mathcad to give me a evaluated value. I only want the final answer but not the expression
Thank you
Can't you just do;
a:=100
x:=50
a/x=2
I'm a bit confused by what your asking if it is otherwise
You are using the symbolic equality, hence the symbolic solution. You should be using the normal = sign
For the numeric engine:
x:=10 guess value
a:=100
Given a*x <ctrl>=50
Find(x)=
TTFN
FAQ731-376
