Crocostimpy
Industrial
Lately I've been including what is basically a shaded ISO view of my part in my drawings. I modify the view and change the Shaded setting to Fully Shaded or whatever it is. I then turn off the lines in the view through View Dependent Edit. The problem occurs when I make a PDF. The lines that I turned off, and which aren't on the drawing on the screen, are mysteriously there in the PDF. I have gotten it to work correctly once, but the majority of the time some or all of the lines show up in the PDF even though they are turned off in the drawing. This is NX5.
Anybody have this problem? Or can give me some idea of what may be wrong? Restarting the session, which usually works for me on other oddities, doesn't work for this.
Mike
Mike
