BrianRoach
Automotive
Hi All,
I have a situation where I have 5 holes of different sizes on a plate. I am currently holding their position using independent positional tolerance callouts on each hole (e.g. hole #1 is specified as diam. 5 +/- 0.5 with a GDT feature control frame specifing a true pos. of 0.1 back to datums A, B & C; hole #2 is specified as diam. 6 +/- 0.2 with a its own GDT feature control frame specifing a true pos. of 0.1 back to datums A, B & C... etc, through all the 5 holes on the plate). This works OK, but I really want to treat all of these 5 differently sized holes as a pattern, and then tighten their tolerances to each other (i.e. have a single feature control frame that applies to all of the holes with a true pos. of 0.1 back to datums A, B & C in the PLTZF and a true position of 0.05 in the FRTZF). If the holes are of the same size it is easy to do this just indicating that all of the holes are in a common pattern by pointing to only one of the holes and then indicating the pattern with a "5X" in front of the specification for the hole. My question is this:
Is their a way of indicating that all these different size holes are in the same pattern so that I can tighten the tolerance on the holes within the pattern?
