Offshore pipeline installation start-up 1
ek4putr4
43
Dear all,
What is the pros and cons of using single cable mooring attached to one of the platform jacket leg for start-up of offshore pipeline laying?
Pros:
1] Easy to install
2] Flexible to manoveure the barge
3] Easy to connect the fuse soft rope
Cons:
1] Too much load at one point on the jacket leg
2] Larger tolerance on the target point
3] Target point would much away from the jacket base requiring longer riser tie-in spool
4] Most operators would not allow
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit
tx naren,
is there any bad effect to the linepipe itself, i.e. stress, span length, fatigue, etc. ?
ek4putr4... it should be calculated when you do your stinger and offramp calcs
