maxgress
- Jun 3, 2002
- 3
A switchgear gear high voltage test section is isolated and disconnected usually by open isolators and the opposite earthing switch to the test section is closed and connected to ground.
Can in a gas insulated switchgear the clearing distance of a circuit breaker with grading capacitors in parallel to its open contacts and the opposite side of this circuit breaker earthed be considered as safe isolation distance for a high voltage test?
Any other life circuits are safe isolated by the next downstream isolator.
