SPRING element in COSMOS
Mister13
7
Could anyone help me? How should i use spring element in COSMOS M program?
The situation is that i need to do buckling analyse and i have a colums, which's top is fixed.
Stifness is 10500 kN/m.
Thank you!
The documentation is pretty clear. Most of the important stuff is set in an RCONST.
Be aware that you can have one node and two/three node springs. One node springs are good for keeping bodies from flying into space as they are basically grounded springs.
As far as you columns go, send a picture. It isn't clear what you are trying to accomplish and what part springs need to play in what you are doing.
TOP
CSWP, BSSE
"Node news is good news."
The situations is, that i have to find out, how much does other column helps (lenght is L1 in the picture) for others columns buckling (lenght is L).
There is a situation shouwn in a picture 2, where are two columns connected with a horizontal element in the top. It would be the same, if i connected column's (lenght L) top with a spring (spring stiffnes is 10500 kN/m) that columns could only move and there will not be rotation, like it is shouwn in picture 2.
Thank you!
 http://files.engineering.com/getfile.aspx?folder=d524c37a-1096-4405-a26e-3a1a0591770e&file=situation.JPG
I tried to use one, two or threee node elements. But all results were wrong..
Interesting, because if i calculate a column, which top is not fixed, results are the same in CosmosM and MidasCivil but if the top is fixed, results are wrong.
Maybe i deleted it, because i can't find it.
I tried to do the same with MidasCivil program, but results were also wrong. So i found out that buckling is correct if there is only one element without spring or other construction.
