21Pom
- May 1, 2010
- 131
Hi All,
I'm have no luck in creating/welding two rods together. They form the base of my fan guard, previously discussed.
What I have, refer attached file, is a circular ring of 6mm dia. steel rod and in the centre to give the item strength, is a cross piece also made from 6mm steel rod.
I have tried several ways to create the weld with no luck. Can anyone offer a solution to the problem.
Best Rgds,
Dave R.
Best Rgds,
Dave R.
