EddyWirbelstrom
An islanded powerhouse consists of unearthed star-connected generators directly connected to a 11kV bus.
The 11kV bus is earthed via an earthing transformer as shown in the attached simplified three-line diagram sketch and the attached single line diagram.
The impedance values were chosen to simplify and are not the actual values. Actual values are shown below.
SKM / PTW program confirms the magnitude and direction of the phase currents for a single phase to earth short-circuit shown in the attached sketch.
I would like to verify the PTW results by manual calculations based on a sequence impedance diagram.
Can anyone suggest the layout for the sequence impedance diagram ?
How is the earthing transformer and unearthed generator represented in the sequence impedance diagram ?
The actual values are not needed, however they are :
Generator – Star connected, unearthed
Sn = 3295 kVA, Un = 11000V
Rg = R1 = R2 = 0.01 pu
x”d = X1 = 0.166 pu
x”q = X2 = 0.186 pu
ro = 0.01 pu
xo = 0.01 pu
Zigzag earthing transformer
Ro = 0.83 Ohm ( 0.0069 pu on 1000 kVA )
Xo = 2.048 Ohm ( 0.0169 pu on 1000 kVA )
R1 = R2 = 999999 Ohm
X1 = X2 = 999999 Ohm
I will attach the single-line-diagram and PTW report in separate postings.
x”d = X1 = 0.166 pu
x”q = X2 = 0.186 pu
ro = 0.01 pu
xo = 0.01 pu
