Metal deck...rigid vs flexible diaphrams
RosePE
1
Risa 3d user's manual rcommends that un-topped metal deck should be treated as a flexible diaphragm. It is common practice in our locale to use metal roof deck as a non-flexible diaphragm. If the decision is made to consider metal decking as a non-flexible diaphragm, would it then be appropriate to input the actual gage thickness as the diaphragm thickness?
It would be appropriate to use the deck properties to create the plate elements which will make up the "diaphragm". Though you might want to reduce the G value for the material to account for fastener slip and such.
