majesus
- Aug 16, 2007
- 262
Basic question on Lockout Relay 86 and power distribution transformers used as voltage step down for industrial sites. Typical transformer sizes are from 10MVA to 500kVA with LV secondary (600V or 480V distribution).
Curious to know at what transformer size do you typically not use the relay 86? I have seen Engineers use lockout relays for 5MVA XFMRS (4kV to 600V) while other Engineers do not.
Safer is always better, but sometimes, your upstream relay doesn’t have the 86.
Just like an opinion on it.
Majesus
Majesus
