Import from HP SolidDesigner?
loeb
29
I'm having a hard time bringing in a third party model that was created in HP SolidDesigner. Regardless of what format my customer sends me, I either get useless entities , or I get what appears to be only surfaces with many surfaces missing or out of place. What I really want to see is solids. Does anyone have any advice on getting parts and assemblies out of SolidDesigner? I can bring them into/through ACAD14, Inventor 4, or SolidWorks 2001.
Have you tried importing with Rhinocad? They have a trial version available at rhino3d.com. This is an excellent product for importing surfaces as it does a good job of healing disparities. It also works quite well with solidworks (I don't know about Inventor). However, if this is a large NURBS file, it may take a while to open after saving to solidworks.
Hi loeb,
May be you can try on the tolerance setting before you import the IGES. After import IGES into SolidWorks, try to check the gap & fix it using Diagnosis. (RMB one of the surface)
Another suggestion is open IGES w/ MasterCAM. It's great!
[yinyang]
