Siemens S7-300 Backup
xJAyx
100
Using Step-7, is there an easy way to connect to a Siemsns S7-300 and create a backup of all blocks and data?
Essentially I would like to take an as-found backup of an existing installation.
Thanks in advance,
Jay
Yes, you need to "upload" from the PLC to "PG". It's in the menu of Simatic Manager.
Alternatively, if you can turn off the system, then you can take out the MMC and copy from there.
