nil ductility temperature (NDT) vs Minimum Design Metal Temperature (MDMT)
eggsontoast28
3
I am trying to determine if the following to topics can be considered one in the same.
My materials are High Tensile Strenght, Low Alloy:
ASTM SA-225 Grade C
ASTM SA-336 (modified)
I am pretty sure that nil ductility temperature refers to the temperature in a material when matter/atoms cease to exhibit kinetic energy/motion.
I have test data for a project that I am currently working on and I would like to make the conclusion that I can equate my MDMT to my test data NDT.
Any help is greatly appreciated.
Gart
A prudent engineer will declare a design MDMT to be 'comfortably' above the NDTT nil-ductility transition temperature. If designing to ASME or API, the 'comfortably' part is taken care of by the mandatory design rules. thus: MDMT > NDTT, unless the designer is an idiot.
