Wood pole foundations for swampy areas 1
Kilowatt47
3
Wood pole foundations: The line passes through swampy areas with very low soil bearing capacity, several types of foundations for the wood pole structures are possible. I prefer a concrete foundation with a column on which the pole is attached to above ground. Now I am told that it is easier/cheaper to take 2 empty oil drums, put the pole inside and fill it with concrete. According to my knowledge wood poles embedded in concrete decay. Any opinion on this?
Like you say, several types of foundation are possible. If you Google Pole Bog Shoe you will come up with a few. I can't see the concrete filled oil drum method offering much stability in cross winds aside from the decay issue.
Marmite
