Activate Terminal Node over entire CATProduct
CheeseMaker13
Aerospace
Sep 25, 2012
42
GB
I need to be able to apply "Activate Terminal Node" over an entire product, but currently I can't work out to get everything (including those parts buried two levels deep in 'components' to load.
I've tried to do it via each first level product, which works apart from no parts in components are loaded:
Code:
    Set CATIA_Product = CATIA.Documents.Open("Path to File".CATProduct")
    Set CATIA_Products = CATIA_Product.Product.Products
    CATIA_Product.Activate
    CATIA_Product.Product.ApplyWorkMode (DESIGN_MODE)
    Product_Count = CATIA_Products.Count
    For i = 1 To Product_Count
        CATIA_Products.Item(i).ActivateDefaultShape
    Next
I've also tried:
Code:
    CATIA_Products.ActivateDefaultShape
And a few other combos without success.
Peoples thoughts?
Hi, absolute top node!
Assembly
- Component (Part 1)
- Component (Part 2)
- Component (Part 3)
- Component (Product 1)
- Component
-- Component (Part 1 - Part 2 bolts)
--- Bolt 1
--- Bolt 2
--- Bolt 3
-- Component (Part 2 - Part 3 bolts)
--- Bolt 1
--- Bolt 2
--- Bolt 3
-- Component (Part 3 - Product 1 bolts)
--- Bolt 1
--- Bolt 2
--- Bolt 3
If that explains it?
So I guess yes, top node!
Hi Mate,
Thanks, but still not working/nothing happening!!
Getting "Object does not support this property or method", error 438.
Code:
    Set Excel_Sheet = Excel_Workbook.Worksheets(Control_Sheet)
    Set CATIA_Product = CATIA.Documents.Open("PATH" & Excel_Sheet.Cells(iRow, Part_Number_Column) & ".CATProduct")
    Dim CATIA_Selection As Selection
    Set CATIA_Selection = CATIA.ActiveDocument.Selection
    ' clear selection
    CATIA_Selection.Clear
    ' select root product
    CATIA_Selection.Add CATIA.ActiveDocument.Product
    CATIA_Selection.ActivateDefaultShape
In a CATScript, for me is working.
Sub CATMain()
Dim objSelection as Selection
Set objSelection = CATIA.ActiveDocument.Selection
' clear selection
objSelection.Clear
objSelection.Add CATIA.ActiveDocument.Product
CATIA.StartCommand "Activate Terminal Node"
End Sub
Fernando
Thanks mate, that works perfectly now!!
Just need to sort the problem out with my clash exporter (see other thread!).
