A pipeline under the regulation of DOT 195 PHMSA and ASME B31.4 can be repaired using Type A and Type B Steel repair sleeves. I am looking for the type and grade of steel plate allowed as specified in the PHMSA, ASME, or possibly the API code. Knowing the Type A sleeve is considered a structural repair and Type B is considered a pressure-containing repair. ASME PCC-2 didn't help. Found good information in ASME BPVC Section VIII and Section II, but a pipeline operator isn't sure Section VIII and Section II are applicable to pipelines. Please provide any guidance on material selection for these steel sleeves. And the trail of regulations that are easy to follow. Thanks.
