  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
How to control the color of an NX object by editing an Expression... 2
JohnRBaker
35,347
A request for this was made some time ago in this forum and so I've prepared a Word document (see attached) which describes the procedure for using KF (Knowledge Fusion) to create a way to control the color of an NX Solid Body (or a Sheet body or even the Face of a Solid/Sheet Body) by editing the value of an Expression. Note that you will need an KF license to utilize this procedure but once the part file has been created and the KF expression created and linked to the NX object, you no longer need a KF licence to use the file and control the color via the Expression.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
So that you can see how this works, I've attached an example part created using one of the these KF enabled 'color' expressions linked to the solid body. The model was created in NX 5.0 so most of you should be able to 'test-drive' this part file. Just remember that you can only enter a value for the expression 'Object_Color' of 1 thru 216, the maximum number of NX colors. The color assignment will be based on the CDF file assigned to the part file.
Anyway, have fun ;-)
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=da764fae-e5f9-4cb6-863a-5990c68d5d53&file=Example_Part_Expression_Controlled_Color.prt
John this worked beautifully and was something I was looking for. Great post, THANKS!
Do you have anything like this on Cloning parts from a custom library???
That's something I really need to figure out and I know that KF supports it.
I would like to be presented with a re-naming field or maybe just be able to set a re-naming prefix or suffix?? Something on the simpler side with a bunch of gingerbread.
I sure I'm stretching on this type of request tho...
TIA
Dave
WITHOUT a bunch of gingerbread that is.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
Not really. I'm not a KF expert. The object color thing was something I got from someone else.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Where did the first attachment go?
Anyway, here it is again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=5e78f114-f593-417f-8e8a-9a70791ee78c&file=Controlling_the_color_of_an_NX_Object_using_an_Expression.docx
That's OK... I'm close to getting it settled. There was a post on here with a part here that had data attached.
I'm a good copy cat.
Have a good weekend!
Dave
NX9, Win 7 Pro SP1
