Brake Slack Adjuster
dha
Materials
Nov 19, 2002
What is the function and purpose of a slack adjuster on the brakes of a tractor trailer? What is the failure rate? What would indicate failure?
dha
The slack adjuster is to keep the brakes adjusted properly. The air chambers that accuate the brakes only have a limited amount of stroke. As the pads wear, the slack adjuster must make up for the wear. All air brakes have an external slack adjuster. I assume you are referring to automatic slack adjusters.
I don't know about the failure rate as a % per year, but they can fail. A common cause is rusting and corrosion from road icemelt chemicals. Some of the new salt replacements can be much more corrosive than salt.
You can tell if the auto-slacks are working by checking the amount of travel in the brake chamber pushrod. The pushrod should move no more than 1 inch when moved by hand. This check must be done with the brakes released. This requires the vehicle to be on a level surface, and please chock the wheels! The human body makes a very poor wheel chock.
Improper slack adjustment is usually listed as the number one reason for out-of-service orders at inspections.
Thanks for the information- very useful.. I was also wondering whether over-braking can force the slack adjuster to open past the specified distance and if so, would this be considered a failure. Also, is there an accepted maintenance schedule or are these maintenance free?
