I am currently working on a CFMS submittal for a steel framed structure and have encountered a detail provided by the EOR which indicates that the light gauge studs spanning between high and low roof framing shall provide vertical support for the brick veneer along this wall. I have already sent an RFI to the EOR regarding this non standard detail and their response was that this detail has been used before. The centerline of brick is offset from the face of the 6" studs approximately 4 inches and the weight of the brick varies between 175 lbs to 408 lbs at the peak of the gable. I am looking for advice on the best way to model this section in order to determine the reactions at the screws (caused by this eccentric loading).
Any suggestions for solving this problem would be appreciated. Thanks.
