Our customer has asked us to re-tube their GE steam turbine condenser, replacing the original 2134 1" OD x .049" (18 BWG) Admiralty D Brass tubes with 1" OD 304 Stainless tubes. There is a section of 304 tubes originally installed as a separate cooling section in this unit that uses 1" OD x .028" (22 BWG). I can use this to calculate that the joint strength will be adequate. What would be the significance on heat transfer?
