Dear all,
investigating electricals circuits in 3 Haitians hospitals , i keep finding odd and stranges things.
the lastest is a connection between padmount transformer and ATS switch cabinet.
three phases , 220 v , 300 KW circuits are connected with the system show below :
i am not an expert of NEC code (ah those French guys!)but it seems that this kind of connections should be insulated with resin and not with tape. and that the hole should be closed with non-fire material.
can I have your expert advices on that "hot" subject ?
thanks for the support
best regards
Jean Michel
best regards
Jean Michel
