jtseng123
- Jun 6, 2012
- 530
Please someone educate me a little bit:
Can ASTM non-pressure part, such as support clips, be directly welded to ASME pressure part for new vessel to get code stamp and NBR ?
For example A-36 welded to SA516-70. Section II states A-36 is identical to SA-36. Are there any special requirements in PQR ?
If that is not a problem, I believe PWHT will still follow vessel code for thickness above 1.5" thick, not 3/4" from piping code which uses ASTM material.
