lager
- Oct 26, 2015
- 28
How would this lag expansion bolt perform when they are used in base plate anchoring...
It looks like this:
When installed under base plate:
When you use 16mm lag screw, the housing that needs to get inside or drilled must be 22mm.. so when you insert the housing inside, there is a gap between the bolt insert and surrounding concrete (22mm-16mm= 8mm) on the upper part.. only the bottom is in contact.. how does the tension breakaway mechanism of this bolt look like.. how does this kind of bolt perform?
It looks like this:
