Non-circular Flange Design 2
manian
Industrial
AE
ASME Section VIII Division 1 Appendix 2 deals with the circular type flange design. but often there is a requirement for designing non-circular flanges particularly oval/elliptical type flanges which are integral part of valves.though the above appendix deals with non-circular flanges, its suitability for the above application is of doubt. is there any other design procedure or approach available for oval/elliptical type flanges ? there is a DIN standard DIN 3840 - but i am looking for still more and detailed treatise on this subject. is there a computer program/software available for such flanges ?
Please check with the ad-merkblat (german p.v. code). If I´m recalling ok, section B7 deals with flanges, including the no circular ones. And probably there are some german software the enables you to calculate them.
Hope this helps
Juan
You may please refer to HEI standards for rectangular flange design.
V.Dwarakakrishna.
Refer to a book by Kanti Mahajan: Design of process equipment. Part C, at least for the 2nd edition, covers the design of rectangular flanges. The design program Optivessel has a module based on this method, visit
Rudo Louw
A.E Blatch has written a paper published by ASME called bolted flanged connections for non circular pressure vessels from “advances in bolted technology 1989” this may be of some help.
What are HEI standards and where are they available from?
