hssbrian
- Aug 24, 2015
- 10
Hello everyone, not trying to get too technical on this matter. I have an existing 10cm concrete slab with some columns located at the footings. This is an open-air structure.
The columns have some minor roof loads (no special snow or wind loads) and the slab does not have any special traffic (typical live load). I am interested in knowing if there is any special consideration needed for the beam-girder connection (see red box in the attached document). If you have any suggestions, reference or connection details it would help.
I personally don't think there should be any issues and consider that if I have enough development length it should be fine. All beams/girders are 30x30 (plenty for what is needed)
Much appreciate all your comments,
HSSBRIAN
HSSBRIAN
