Real time X-ray sources
HiGroove
10
I am looking for a source for real time x-ray equipment. The application will be aluminum die cast automotive components.
Can anyone help me ? I am located in Northwest Ohio, the closer the better.
Thanks in advance.
We currently use real-time x-ray on castings. I would suggest you look closely at your requirements, as it can open up a whole can of worms, what you thought were good castings on the outside suddenly under x-ray have levels of shrinkage, which leads to the moral question do you try to fix problem or let sleeping dogs lie.
In addition you will find there is a general vaugness with customers over defect levels, If you give a customer a chart and suggest that level 4 shrinkage sponge would be acceptable, he will think "no, i want level 1 or 2" this would make the part aerospacce quality and therefore command aerospace prices.
Companies to try are
Feinfocus
and
ABB
BOSELLO is an Italian company that has been making real time X ray system for more than 30 years. They offer a lot of technical advice as well as supplying the equipment. They have a nimber of off the shelf systems.
You could try North Star Imaging ( They do great work and offer classes on x-ray inspection. In fact when I went through 3 of the other students were looking at your exact application.
Good Luck!
John Salls
Applied Vision Systems, Inc.
I own a company that manufactures x-ray inspection systems. We have been doing this since the early 70's.
I can be contacted at: realxray.gte.net or (727-524-2500)
I am more than willing to look at your product,inform youas to waht we can see and cannot and send you images.
We do not charge for this.
Robert A. Scelzi
President
NIS/Realxray
Clearimage technology located in California is a company that specializes in real time x-ray inspection (310) 258-9729.
