UNF Thread Profile
SORJM
Computer
Apr 5, 2016
30
I wanted to create a bolt and nut on the basis of following thread profile available at wikipedia. I have a little bit of confusion so I though I should take help from experienced people present here. As I can understand from the following image for internal and external are same that would be used to cut threads on bolt and nut both.
Or different profiles should be used for nut and bolt please suggest.
The profiles must be the same, else you will either not be able to screw them together, Or, there will not be a good fit, and then the connection is weak, Not as strong as intended.
But, the screw is slightly smaller than the hole. Else again you will not be able to fit them together.
/ Tomas
Thanks for the reply. I think an another thread profile available in the mechanical engineering handbook will be more suitable because it has described internal and external in separate way. When I would complete it post it here... [glasses]
