charge cooling
Vapo
Automotive
Dec 6, 2002
3
wondering if anyone's heard about the cryogenic system that uses CO2 to cool aair as it enters the intake manifold....I found a site on the internet that sold the system but been searching like mad and cant find it again....HEELP !!
I have heard of LIQUID propane being injected upstream for use as charge cooling. PWM control with a tfe valve. The stuff looks blue. Problem is its only good for drags. The tank freezes up and discharge pressure drops to zero.
You should read some points in another thread called fuel Temperature. IT will offer some additional thoughts for you to add to yours.
Shaun TiedeULTRADYNE Arl,TX(stiede@ev1.net)
